can any one help
GKH
West Yorkshire
hi all
Having parked my 129 sl 320 for a month i returned to find the speedo did not work the garage have told me its the instrement cluster and quoted 1200 pounds any one know of any where that repairs them
best regards
glynne
GKH said:
hi all
best regards
glynne
lets start again the VIN number first 6 numbers please
The speedo head is separate on this car right up to the end 129064 car
Malcolm
G
GKH
West Yorkshire
hi malcom
first 6 numbers are 129063
regards glynne
mioba
Nottingham and Köln
GKH said:
hi all
best regards
glynne
bba rahman (think thats how its spelt) and speedofixer
do a google
the possible causes ar the inductive road speed sensor or the speed signal from theABS or ASR control unit N30
All in all it is not the cluster, as I said earlier the speedo head is a separate unit, I would think that you only have a poor connection some where. I do not know how you will find it without the test gear, start by unplugging the module mentioned above and re inserting.
Malcolm
G
GKH
West Yorkshire
thanks
thanks malcom thats what i think at the garage they took out my dash and fitted one from another car and it worked when they put mine back in it worked for a while but seemed to be dampered then it stopped working after about 8 miles
regards glynne
regards glynne
OK they are easy to work on and the speedo unplugs from the board, I feel it will be a crack in the PCB, but that can be bridged. what ever you do not need the whole thing, I repaired one 2 weeks ago, after I found a definite fault.
Malcolm
G
GKH
West Yorkshire
thanks malcolm i will strip it tomorrow and let you know what i find
best regards glynne
G
GKH
West Yorkshire
thanks mioba its bba-reman.com
best regards
glynne
G
GKH
West Yorkshire
hi malcolm
unpluged every thing sprayed with contact cleaner works fine thanks
best regards glynne
As stats,very pleased, sometimes I think that the world is a crazy place in that MB people don't even try, it makes me angry that they do not care one s--- about how much it cost you, or should I say us.
Malcolm
