can't turn ignition key
Status
Not open for further replies.
bracky
scotland
g reg 230 te estate auto
got up to go to work this morning and the ignition key wouldn't turn, no matter how i jiggled the steering wheel.  same again tonight.
anyone got any ideas
cheers
bracky
dave elcome
Maidstone kent
Sounds to me as if the key is worn, i had a similar problem with mine a little while ago when using the drivers door lock.
The fault was rectified by getting a new key from the local dealer, you will have to order it, with chassis numbers and personal ID etc, (unless Andy can help??).
Andy
West Midlands
www.mercedesservicing.com
The problem is the ignition barrel is breaking up inside. Usually (and the customer almost always invaribly denies it) The key starts to stick or you have to jiggle it to get it to turn. These are the first signs.
If you can get it to the ignition and start. Pop it straight down your local MB dealer or specialist. Whilst the key it in the number 1 position. The barrel can be removed. Takes a few seconds with the right tools. If not I am afraid its a new ignition lock assembly. It could take an hour or two to replace.
For all those with 124's\190'\126's if the ignition barrel starts to stick then get replaced as a matter of urgency. Or it will jam completely.
IGNORE AT YOU PERIL!!!!!
If you supply chassis number to MB they will supply a new barrel to the original key. Takes about 7-10days. Or get another of the shelf.
Hope I have been of some help.
Regards
Andy @ www.mercedesservicing.com
Stewart Smith
Hartlepool
Might sound daft but I once had a do with a Bedford CF auto van - it was the gearbox selector safety switch - not only did it not let you start the van in D, but it had a solenoid which would not let you turn the key.  When the selector microswitch broke, I assumed because the key wouldnt turn that the lock was faulty - took me ages to figure out that I was wrong.
B
bracky
scotland
thanks for the replies guys, i've ordered a new key 'cause thats the cheapest, if that doesn't work then i'll take andys, problem is, if i can't start it i can't take it to a dealer. my closest is thirty miles away
simon
East midlands
I had that problem.I was warned as per Andy & had the barrel changed.Problem solved,safe & quick.
ernest
dave elcome
Maidstone kent
Bracky.
Take Andy's advice, when i got mine there were 2 keys, one for the doors, the other for the ign. I got a new barrel from the dealers, made up to fit the original key spec,  piece of cake to fit, now no more gropeing in the dark trying to find the right key.
Matt Crooke
Essex UK
Ex Telecom Van eh....?
Did it come complete with the Hanging Buzby on the rear view mirror?!
Oliver Francis
Twickenham
Andy
Igniton key wont turn.
You dealt with this 26 Jan.   I have same problem but since I can't start car (260E) I shall have to get lock out myself.
Friendly, and good, mechanic says to screw slide hammer into lock and bang away.  Is there a less brutal way?
Andy
West Midlands
Hi Oliver,
Once the key is jammned and you can't turn it at all. Then you have to remove the complete assembly. No way around it I am afraid as the barrel has broken up inside.
Drop the undertray and follow the steering lock assembly down. By the bracket with the 10mm bolt through it there is a small round brass coloured pin. This pin usually can be depressed when in the No:1 position. But because you can't turn the lock you will have to either drill it out or grind it out. You will then have to replace the  complete assembly.
Hope this helps
Regards
Oliver Francis
Twickenham
Andy
Thanks for info on igntions key.   Do you know where I can get a new unit and is it going to be any dearer to match the existing key
By the way, we get some coolant loss.   It never stays up to the mark on the coolant bottle but I don't think there are any leaks.   Used to get the same on an Audi.
How about the pressure cap.
I don't know whether I should have started a new thread here.  I don't know the protocol.
Andy
West Midlands
Hi Oliver,
You will have to get all parts from the dealers. They are not excessive in price.
Parts Req:
Ingnition barrel
Ignition barrel cover.
Steering lock mechanism.
Light buzzer loom.
That should do you.
As for the coolant loss that could be any thing. Check all obvious things like coolant pipes, pump etc. Have the system pressure tested & also check head gasket.
Regards
Status
