car wont start
Jon72
We have a Mercedes C240, bought it 3 months ago and have had nothing but trouble with it!! we had it serviced and a few other bits done, it has been making a intermittent grinding noise when accelerating mainly seems to be up a slight hill, then last week the car cut out whilst waiting at traffic lights, same happened again 2 days ago! today been out in the car no problems until i just tried starting it, and it will not start!! it turns over but will not start.:mad:
anybody any ideas really appreciate it... before we go out and buy a new starter motor!
AMGeed
Poole, Dorset
S204 C180K
If you are trying to start a warm engine and it fails to start it could well be the crankshaft position sensor. Does it start normally from cold? Common problem on W210's, but fortunately not too expensive at around £60
Jon72
It has been a 5 hours since i last used the car & yes it normally starts ok 1st time!
AMGeed
Poole, Dorset
S204 C180K
Sounds like it needs to be hooked up to a Star to find out exactly what the problem is. Buying another starter motor won't necessarily cure the problem, especially if the engine is turning over.
Maybe someone else can give some other ideas?
Cole@MBS
www.mbssouthampton.co.uk
Crank sensor all day long on that engine!!!!!
Cole@MBS
The car cutting out yes, grinding noise no!!
Jon72
Is this a part that i can buy & fit myself?? Is it fairly easy to do?
Struggling to find the part! got a quote from a local garage £170 crank fitted & cps reset ....does this seem ok??
Jon72
Got a part from Mercedes garage £90.85!
Once this part has been fitted will i have to set the vehicle computer to start the car??
Jon72
Also can anybody advise on where to find pics on the location of the crank sensor inside the engine and what size tools is needed? we have a friend coming round later to fit it but he has never fitted one before
teddycatkin
cheshire cheese country
I agree sensor is a common fault--get a new one on 1st and see if it cures your problems - let us know ?
Jon72
  • #17
Yeah will do, but just are just trying to locate its position in the engine atm!
Cole@MBS
Rear of the engine to the right as you look at it, pull the top cover of, just behind the right hand side head, got a 2 pin square plug going to it!
Jon72
  • #20
Well what a nightmare we are having with this, last week our friend tried to fit the crankshaft sensor but was unable to do so, he found it very difficult to get to it (never fitted one before). We have now taken the part along to a garage who quoted us £35 to fit it, he was unable to get the old one off apparently it does happen!! & now he has to take the gear box off in order to fit the crankshaft :shock: £500 the bill went up to :shock: but as we are paying cash it suddenly dropped down to £300 :rolleyes:
This is a Mercedes specialist in droylsden Manchester have we been had yet again? or does this seem okay?
cheers
Tel: 020 8863 9233
