Legoman
heres one for the guys with mechanical knowledge (probably a mercedes mechanic)
i had the catalysts removed on my car as they were knackered and its pre-cat year car. now after i was browsing i found this
http://www.detali.ru/cat/oem_mb2.as...GM=717.450&CT=M&cat=520&SID=01&SGR=065&SGN=07
if you read the bottom text , part 004 (*004 ON VEHICLES NOT EQUIPPED WITH CATALYST,LOCK AIR INJECTION BORE BY MEANS OF 104 016 00 33 COVER)
what the hell is this and should i now get this part and block whatever its on about?
i havent a vague idea what its on about tbh. its part '59' on the image and seems to go on the exhaust side from what i can see. so is it that pipe that comes out of middle and should i remove it?
