Catalytic converters
martinaltury
valencia spain
clk 1999 3.2
Well I'm still trying to sort out my bad co2 reading for mot after changing many parts today I removed the exhaust system I worked out the 220 CDI has 2 catalytic converters and the second ones empty I think I it's possible the next part I need
whats an egxorst system.
Not every member has English as first language and nor are they all based in the UK… it’s also really easy to mistype (I know I do it often enough)
martinaltury
martinaltury
valencia spain
clk 1999 3.2
Well I am English I just had a bad spelling moment can't all be perfect
mioba
Nottingham and Köln
Maybe one of the cats were removed by a PO as it was faulty. Is there any signs of being abused down there.
Good luck and keep us posted. Indeed we all have typo days especially with sausage fingers and typing on smart phonez.
Tony Dyson
God's Country
2014 C 220 CDI W204 OM 651
I found this confusing as I thought I only had 1 so I looked it up here for confirmation https://mercedes.7zap.com/en/eu/fg/.../49/0/218/0/0/?param=vin:wdd2040022a924672#40
I think the confusion is yet another example of definitions 'Lost in translation' again, from Mercedes original German, Items 20, 40 and 10 (DPF) in the graphic are described collectively as "Catalytic Converter System" which I suspect is why I have also seen references to the DPF, Item 10, being identified as the 2nd CAT?
I don't know what is inside the Catalyst, Items 20/40 but if you are referring to the DPF as the 2nd Cat, then, this shouldn't be empty.
This is of course MY C 220 CDi exhaust system NOT yours! so I have made assumptions that you may possibly have the same or similar, visit the website posted above and confirm what you actually have!
supernoodle
E220 2005 2.1D
I guess you mean CO rather than CO2? There's nothing in the exhaust to reduce CO2, but a diesel oxidation catalyst does convert CO into CO2.
martinaltury
martinaltury
valencia spain
clk 1999 3.2
Here are both cats top one is second cat bottom one is first and I have no Lambada censers IMG_20220109_193222.jpg
Very unlikely to be a DPF on Euro 3/4 car....
supernoodle
E220 2005 2.1D
Mot doesn't care for anything but smoke and I expect the Spanish Itv is the same. I notice OPs other posts talk of exceeding the plate value of 0.8, that must be smoke?
martinaltury
martinaltury
valencia spain
clk 1999 3.2
Yes plate value is 0.8 on the smoke test mine reads 1.75
martinaltury
martinaltury
valencia spain
clk 1999 3.2
Here's the cat and it's empty A2024900036 you can read the numbers on the cat IMG_20220110_003937.jpg
V6Matty
Newark, Nottinghamshire
the Cats won’t make any difference to smoke, you have another issue, what is the colour of the smoke, grey or black?
martinaltury
martinaltury
valencia spain
clk 1999 3.2
  • #17
Was going to try to upload video but the files to big just a bit of black at 5000 rpm
V6Matty
Black would be incomplete combustion, so have a look at boost leaks as a start, from there you going to have to go through the system bit by bit to find where the issue lies, worth doing the glow plugs too, as they are in use all the time to lower emissions (in turn less smoke).
martinaltury
martinaltury
valencia spain
clk 1999 3.2
  • #20
It had new intake manifold new intercooler all pipes off cleaned and checked heater plugs out checked and back in I have a catch can on breath 3 lots of injector cleaner it runs like a dream and it's got 180000 on the clock
