grahamwoodward
Midlands
www.gwoodward.co.uk
W211 E320 (petrol) Avantgarde Saloon (2004); CL203 CLC180 Kompressor Sport (2008)
Hi. The CD cartridge in the glovebox on my W203 C240 (2001) will not eject. CD tray 3 is loaded into the player but will not retract when you press the small green button on the unit to eject the cartridge. The audio unit (a Radio Audio 10 unit) reads "Track **" for a few a seconds then says "No Mag".
How do I get the unit to eject?
Roxie
Lincolnshire
C Class 350CDI 2012
I had the same thing with mine a few months ago. I took the changer apart removed the disc from the player and put it back together again and all is still okay, I think it was because I had a writable disc in it. They are a bit thicker.
grahamwoodward
grahamwoodward
Midlands
www.gwoodward.co.uk
CD changer jammed
Thanks. How do you remove the unit from the glove box?
Roxie
Lincolnshire
C Class 350CDI 2012
One screw up into the top of the glovebox and hey presto it slides out. Two plugs on the back one for power the other is optic fiber.
To take it appart is fiddley, but basically just a case of watching what you are doing and undoing the screws. Be carefull of the springs at each side that support the carriage.
grahamwoodward
grahamwoodward
Midlands
www.gwoodward.co.uk
cd changer jammed
Thanks - I'll have a go; look east towards Nottm for low flying springs!
grahamwoodward
grahamwoodward
Midlands
www.gwoodward.co.uk
Sorry to be a pain - I Can't get the small wire connector out the back of the unit (I think it's the power cable). Any special way I should know about? Thanks
Roxie
Lincolnshire
C Class 350CDI 2012
No. I think that there is a tab to release the most connector but the electric wire is just tight but look for a similar tab.
