CDI 220 Automatic transmission problem
fknowles@uk2.net
I recently had an auto transmission problem in Ireland when the Box stayed in 1st gear only. The mechanic came out and said that the box was in Emergency mode due to a gearbox problem.
On stripping down the box the garage indicated that the gearbox transmission fluid was dirty and should have been changed earlier by my service agent (a properly acredited MB dealer).
On my return to England I wrote to my garage and they said that they are not recommended to change the oil unless the customer reports a problem!!!
Surely if I report a problem it is then possibly too late for remedial work. Am I missing something here or ar MB not taking responsibility for their recommendations. Do you think that the recommendations are reasonable?
carabind
Lancashire
e class
how old is the car ? and what's the milegae? This will make a difference.
During 1998 MB took away the dip stick and said they are filled for life, two years back MB have been forced to back track on this, and now they say change along with the filter at 60k miles and this is what we are all doing
elephantmemory
East Midlands
CLK Emergency transmission
My CLK 430 Auto has just locked into 2nd gear (EM TRANSMISSION) anyone know where the auto-transmission fluid levels can be found on the V8 engine.
I found what looks like the reservior on the front right hand side (when facing car) but there are no markings on it! Also I have removed the cap and the level is not touching the small dip stick which is enclosed!
Also what grade of fluid should be use DOT etc.... and does anyone know how to do the EM Transmission reset.
Regards
tina
BlackC55
South coast
C43
There is no "re-set" that you can do.
The level is checked with a workshop dipstick. There is not a resevoir under the bonnet.
Mb fluid only should be used.
I recomend the fault codes are read first.
BlackC55
South coast
C43
You will have to take it to a garage for that.
A specialist is probably your best bet. Where do you live? Maybe we can direct you to one.
