Central Lcking ML270 cdi 1999 reg Help?
fourteen0407
Walsall
ML270 CDI 2000
hi all, please can you help i am having so many problems with my car but i dont want to give up on it yet.
fistly, the drivers rear door central locking motor is playing up, when i close the locks from the remote, all locks close and then open and then close but the rear drivers side door never closes and does not open on the button, you can open it manually.
i want to change the motor but dont know how. i took off the panel but cannot see how to remove the motor, any help?
second, i want to change steering wheel on car is its wordn, i bought the tools a t25 torx and 10mmhex but i cannot seem to locate the screws at the back of the steering wheel, i place the t25 up the hole but can not find the hole.
any help.
thanks.
margaret.
I can give you the info for changing the door lock motor,, the torx bit needs to be 2" long to reach the airbag screw.
Welcome to the forum
Cosworth
You can change the the steering wheel, you need to have to have a long torx 30 to remove the airbag. Remember to disconnect the battery first other wise you will have a permanent airbag light on.
I will have to find it and print it off
Info sent for door liner and motor
