Central locking vacuum pump
syd harris
I have hunted everwhere for central locking vacuum pump on my 1996 SLK, HELP does anybody know where it is?:confused:
type49
It's in the boot. Remove the spare wheel and it's to the right of that enclosed in thick foam. Why do you need to find it, what is the problem?
syd harris
The battery keeps going flat and the central locking has stopped working at the same time. I think water has got in and damaged the vacuum pump. Think thats whats draining the battery also.
luders79
London
W210 estate
I've had a couple of these do similar things and had got water in to the CDL pump. I know that the SLK (170 chassis ) do have a bit of a probelm with the seal that sits on the rear of the roof. It's the seal that seal's up against the boot lid when boot is closed. If this seal is leaking it can also fill up the rear ABS sensors aswell. Hope this is of some help!
Lee
You do need to put an ammeter in series with the battery. when you do the reading ,do allow for the boot lamp.
Malcolm
