centre console bulb in w220 s class
garytitley
Banned
mercedes e 320 cdi avantgarde
Can anyone help,finally got round to investigating why my centre console is not lit.Removed the plastic led/bulb assembly only to find no wire connected,looks like someones changed it in the past and has dropped the wire,bugger.Had a look if i could retreve the said wire but as theres bugger all room,can get one finger in the hole(no pun intended) it looks like this methods not going to work.The only other way would be to remove the center console inner but his looks like another major headache.Could someone help please,some info on how to remove the parts with out damage would be helpful.Cheers.:rolleyes:
I will see what is involved for you
G
garytitley
Banned
  • Banned
Thanks malcolm
I have the how to remove the center console details, I need and Email address
G
garytitley
Banned
  • Banned
Cheers malcolm,you have pm.;)
2 papers sent,if you need more please ask:D
G
garytitley
Banned
  • Banned
Cheers malcolm,your a star.:D
The papers have been returned "address not found"
G
garytitley
Banned
  • Banned
Hi malcolm,just read the above post been at work hence why i haven't replied until now. I have checked the email address i sent and its fine so can't understand why your email did not send so i'll send you another pm with my email address.Cheers gary.:rolleyes:
I have sent another 2 alsdo I have removed the dot on the end,,see what happens
barry jones
Warrington
2016, LWB W222 AMG Line S-Class S350d - W415 Citan Van too :)
Gary,
you access the back of the centre console light unit by removing the vent and plastic panel from the rear of the console. The vent assembly is only clipped in and just requires levering out using a trim tool or flat plastic strip or similar. Be very careful once this unit is loose though as it too has a cable attached which is the illumination for the vent assembly. Don't pull too hard or you will break the connector (like I did!)
The bottom of the vent sits onto the air pipe which runs under the console. Once everything is removed you will be able to see the hole in the back of the console box and the cable should be in there somewhere.
If you need to get further access, the blank panel at the bottom of the back of the console will also come out. Again using the flat tool, prise the top away from the console. Once it is loose, the panel just pulls up and away from the console.
Refitting is the reverse, but don't forget to plug the connectors back in and be careful to ensure that the cable for the lamps does not get trapped when you refit the vent. It is possible to get the cable between the vent and the pipe which means it will not sit properly.
Just one note, mine does not have the rear ventilation controls but I imagine that if your does, it will just be another cable to unplug and plug back in again!
Hope this helps
Baz
G
garytitley
Banned
  • Banned
Cheers baz,thats great thanks for the info:D
G
garytitley
Banned
  • Banned
Thanks malcolm got the emails you sent,will have a look and hopefully have a go tommorrrow.:D
G
garytitley
Banned
  • Banned
malcolm you have pm.:rolleyes:
I got the PM but cant help on this as the diagrams cannot be printed out with any meaning, so sorry :(
G
garytitley
Banned
  • Banned
Ok malcolm,thanks anyway.:D
