Centre console flashing like a strobe light
dec1777
Got a 2002 E220 W211 and the centre console where the hazard lights button lives occasionally goes through a phase of flashing like a strobe light.
The ESP also cannot be switched off with its button on the same panel, and the button to retract the headrests also does not work.
any ideas where to start looking. Im not too bothered as I dont have much need to tun off the ESP or retract the headrests (if thats what it is supposed to do) although the strobe flashing is a little annoying
thanks in advance for any tips
D
dec1777
  • #2
just had another thought .... the dealer did mention that it had a problem with its Radio some time ago , is it possible something wasnt reconnected properly?
How easy is it to remove the panel to have a look
Ellsy Tanners
Mars
It could be a fault with the upper control unit itself, or a front sam unit, it needs the fault codes red to be sure I think.
Ellsy Tanners
Mars
Does it move up on the button to get to the cd changer or storage hole?
I will try and look at the circuit, could it be a loose plug at the rear of the console, it is not a normal fault
D
dec1777
That is what i am hoping.
Before getting screwdriver out, any tips for getting to the back of the panel?.
I dont want to miss a hidden tab somewhere and end up breaking one if i can avoid it
the door lock/unlock buttons also work fine.
I do have the removal how too papers, I take it its foe the normal radio and not the Comend
D
dec1777
yes its the normal radio.
malcolm, thanks for the second time in as many threads
Dec go to your user CP and activate your Email address, dont forget to click save
I have sent a few, if not right or you need more please ask
D
dec1777
thanks malcolm, looks pretty straightforward, I think its a job for this saturday and plenty of daylight.
those instructions will help remove strip, radio panel and ashtray, I am assuming it is then a case of using standard radio wedge keys to pop the radio out or else some easily visible screws
tnx again
