Changing Brake Pads on a W164 ML
230K
Belfast
E300TD/1998/3.0 Diesel
Is there anything special to do on a 2006 ML320cdi when changing the brake pads?? Do is need reset on STAR or anything silly?? Can calipers be pushed back like normal, are they brake by wire or anything like the early 211's?????
Neighbour has asked me to change them for him, just havent said yes or no till i investigate.
Anyone???
Thanks in advance,
230K
Would you like the 2 work sheets on doing this,, nothing to re set
jibcl500
Cambridgeshire
CL500,ML55,SLK280
Front or rear both easy, make sure you clean and remove all crud before fiiting the new pads, only buy MB pads as they come with all the parts you need.
jib
230K
230K
Belfast
Thanks folks, was just concerned that it was the SBC or whatever the electric braking system is in the 211 & 230's but if it is a normal hydraulic system and the warning lights do not reset then i will be fine.
Shouldnt need the printout from WIS.
Thanks again,
230K
