CrustyClam
- Jan 28, 2017
- Age
- 53
- Location
- Warrington
- ML63 2007
Recently I have felt my car has being suffering from a harsh ride., anyway after a decent drive today I stopped to fill up at the shell garage. On starting the car I had a malfunction error appear related to airmatic, drove home ok, turned the car off and on, the error on the display disappeared.
The error code (historic and self cleared) was Check component Y53y2 (left rear solenoid valve 2) in assembly Y53(left rear axle damping valve unit)
Does anyone know if this is likely to be the airmatic shock itself, or is it referring to the valve block in the engine bay that supplies the air to all the struts?
Also given that the code refers to damping, could this maybe explain the harsh ride?
I have my car booked in for the 17th for a check on the transmission and an overall suspension check, hoping the fault won't become permanent before then. If the suspect was the valve block I could be tempted to order one before my car goes in.
