Is there a simple way to check on software/hardware updates and recalls on my W209 2008 CLK280. The service history is all MB but does not mention this.
# Launch Date Recalls Number Make Model(s) Concern VIN Start VIN End Build Start Build End
1 10/11/2008 R/2008/147 MERCEDES BENZ M-CLASS, SLK-CLASS, CLK-CLASS, E-CLASS, C-CLASS, R-CLASS & A-CLASS. engine emergency shut off, on board diagnosis or tank/speedo signal may be affected 01/01/2004 08/10/2008
Recall Details*
Concern : ENGINE EMERGENCY SHUT OFF, ON BOARD DIAGNOSIS OR TANK/SPEEDO SIGNAL MAY BE AFFECTED *
Description : Possibility of transfer of incorrect control unit software which could affect engine shut off control in an emergency situation or the on board diagnosis system or tank/speedometer signal *
Remedial Action : Recall affected vehicles and replace SAM control unit *
2 17/11/2008 R/2008/149 MERCEDES BENZ M, C, CLK, E, CLS, S, R & G- CLASSES. engine could lose power. 01/01/2006 31/12/2007
Recall Details
Concern : ENGINE COULD LOSE POWER.
Description : The electrical connection in the interior of the crankshaft sensor's chip housing may be interrupted, which may result in loss of power and the inability to restart engine
Remedial Action : Recall affected vehicles and replace crankshaft sensor
Thanks for all of the comments, I was rather thinking about software updates as I have seen a number of posts regarding Command, Auto Gearbox updates, and other general computer software updates. I wondered if the dealer/Indy could identify any missing updates, if any, on Star.
