Checking Diff oil levels W124 e220
Kully E220 Coupe
Hi Guys,
Is there anyway of checking the diff oil level (W124 e220) and is it worth putting ZX1 into the diff, i've read on a few forums that it supposed to improve the lubing of the diff?? is this true??
Kully
MotardMan
Berkshire, UK
1995 E320T, S124, W124, Sportline
You have to get under the car and remove the filler. You'll need a hex tool (Halfords do them) to remove it.
To check the oil, poke a finger in the filler hole, if you get oily, it is full. If there is no oil on the finger, then fill from a squeezy bottle of EP90 until it dribbles out the fill hole, replace the plug and you are done.
I cannot help with the ZX1, I use Massey Ferguson EP90 and have never had issues.
MotardMan
Berkshire, UK
I just checked out the website for ZX1. I would not bother if I were you, if you are concerned, then simply change the oil in the diff more frequently.
As MotardMan I would not use additives
All MB diffs look messy
K
Kully E220 Coupe
Cheers guys, this is what i'll be doing this weekend, hoping for oily fingers :D:D
Kully
kth286
E320 Coupe 95
two potential problems if no car lift.
1. can you get under the car to do the necessary ?
2 if not, can you lift the car sufficient, and can you lift it on a level keel front to back and side to side ? so that you check is accurate.
