Last week I bought a car charger for my mobile phone. When I went to plug it into the lighter socket however there was no power provided to it. I tried it with engine running as well as just the ignition on and got the same result.
To double check the socket I tried to use the lighter, however I found that you had to push and hold the lighter button in to get it to heat up, every other car I had you would just push it in and it would pop out when ready.
I returned to trying the charger again and found that if I pushed it in very slowly there was a point where the LED on the charger would flash on and then off again. I couldn't get it stay on though.
Is this a common problem (I did check older posts but couldn't see anything similar) or something unique that I should get the garage to check out for me. The car is a 1999 CLK 230.
Any help or advice would be very much appreciated.
