I have stuck the car on charge after the battery has been flat for about a week. The ignition key goes in, turns but instead of starting the engine it clicks a bit and then displays 'Key Card not Recognised'
I have searched this forum and the resynch method is to leave the key in the ignition, right? Should the key be left turned on, with the dashboard all lit up, or just left in the off position?
Is this the right method?
Is there anything else I should worry about?
