CL500 Fuse Chart - 2001
Dash1
No longer a forum member
Can anyone email me a fuse chart for a 2001 CL500 - cigarette lighter socket not working and need it for Sat Nav johnbaldwin99@msn.com
Hello John,
Is this an optional sat nav you are deciding to use, or part of the COMAND unit? If it’s a “stand alone” unit and you wish to use the cigarette lighter then the fuse you are looking for is found in the fusebox at the side of the dash on the driver’s side. Remove the inspection cover/panel and it’s the last fuse at the bottom – Fuse No 86 - 15 amp (blue fuse). If this fuse is blown, then maybe you should investigate as to why it’s blown in the first instance.
Best Regards,
Dash1
