Could anyone tell me the colour of my newly aquired CL from the VIN plate ? The No is WDB2153752A009935. Thank You
Thanks TV, the handle is half blue but just chrome would suit as a replacement. Do you know of any info on how to remove the passenger side door card on a CL W215 ?
After further research I have now found out that some cars dont have cards but smart keys. I think mine is the latter. There are two keys, both are chrome and black. Each one has a small red light which pulses when you press one of the three functions. Nothing happens when you press the pad on the car handle with the keys in range, so entry has to be made by pressing the unlock button on the fob. Once in the car I have tried the keyless go feature by pressing the shifter button, pressing the footbrake first and a message comes up saying chip card not recognised. If I assume that the keys are indeed smart keys then the problem might be on the car as neither keyless go or entry are working. Q Is there a transmitter box under the rear seat that needs re setting ? or is it something to do with putting the key into the ignition and pressing one of the fob buttons to reset it that way ? or is it a case of taking the car for star diagnosis ?
Thanks TV, I have looked at the keys, one is very new with no wear and has 1 battery, the other older key has 2 batteries. So assuming the older key is also a replacement, if chrome keys didnt appear before 2008 then both must be replacements and I need to get a card. I need to get Sherlock Holmes to investigate.
