CL55 AMG 2001 (W215) Fuse Diagram
Higs
CL55 AMG
Dear all,
I currently have a CL55 AMG 2001, and just recently my Heater has stopped working. i am hoping that the fuse has blown and can be easily fixed, however i cannot find the fuse diagram supplied with the car. i was hoping some of you nice MB owners would kindly upload or email me a copy?
Your help will be really apreciated.
Higs
Alex M Grieve
Broom, Warwickshire
Dear all,
Your help will be really appreciated.
Higs
Hi Higs, and welcome to the Forum.
I don't have the same car as yours, so my fuse map would not help - but it should come as an A4 sized sheet in a robust type of "fablonised" paper and originally in the boot, either folded and tucked into the tool tray alongside one of the straight tools, or around the spare wheel well. As that is an area which is seldom accessed, it may be lurking in there somewhere, unless someone has intentionally removed it.
If not, I am sure someone will help.
whitenemesis
CLS55 AMG '05
As Alex says or perhaps in the fusebox, drivers end of the dashboard, or (rarely) in the front SAM in the engine bay (upper left corner as you stand before it)
H
Higs
CL55 AMG
I checked yesterday and could not find it, will try again... thanks for the input guys, how many fuse box`s should there be ? i have located 1 behind my seat, 2 in engine bay either side..any more?
cheers guys!
I will try and look this up for you this evening
H
Higs
CL55 AMG
thanks Malcom
On The VIN is your car a 215.37 or 215.374
H
Higs
CL55 AMG
Hi Malcolm the VIN is 215.37, thanks again.
Do you think that my Blower resistor has failed ? as i only got air flow one speed on Auto. when i max the fan control i dont get no air flow through vents, only a steady slow speed?
Higs
Yes you have answered the question, if the fan is only running at the min speed, then this should be just the reg pack
It would appear from the timing on some of these post that this mainly happens when the air intake box fills with water, due to the drains being blocked.
H
Higs
CL55 AMG
Thanks Malcolm..a great help!
if its the reg pack can this be easily replaced? where is this located ?
also what should i check for blocked drains etc ..
thank you in advance
Higs
H
Higs
CL55 AMG
quality thanks Malcolm, if can print off the how to do it paper that would be awesome!
thank you.
2 papers sent one for the reg pack and one on how to clear the drains
H
Higs
CL55 AMG
Got them Thank you malcolm, you have been a great help! will let you know how I got on
Cheers
Higs
