- Mar 14, 2005
- Age
- 89
- Location
- Daventry
- 2002 SL500, 216 CL500, all fully loaded
When using meters, a clamp meter is fine for seeing that you have a leak with disconnecting the battery in the first place, but it is a miserable thing to work with as it has to be reset, to get an update or change.
This leaves the simple multirange meter as being the best all round tool. Ideally a 20 amp one is the best, but a 10 amp would be fine. If the car is cold and gone to sleep that will do the job well. one can always put a shunt on the meter to increase its range.
I am going to do a DIY on this over the next few days, to save keep writing it all out.
Your car does not have an OVP relay, and even if you would they do not cause leaks or current drains
