Datsun-des
Hi guys, I recently purchased a 2002 cl600 and it has developed a fault.
Soon after I got it the check engine light came on, a local garage said the fault code was a temperature sensor so reset it for me and ordered a sensor. A few days later the light came on again so I booked in to have the part fitted. It was fitted but another couple of days later the light came back on and I have rebooked in to have some investigations done.
However, today when I went to use the car, it won't start, the check engine light is still on, everything powers up, but when you turn the key nothing happens. I have looked through the paperwork supplied with the car and it had a similar fault recently and a garage cleaned the fuse box connections and refitted the relays etc to fix it. I'm suspecting there is more of an underlying problem. Any ideas where to look?
The cars other faults are a slight exhaust blow, the keyless entry/start doesn't work, and the full open/closure is very intermittent. I suspect these are completely unrelated though.
