CLC new owner a few questions
Dinalli
Picked up my 08 CLC yesterday and so far im very impressed esp with the comfort of the drive.
Anyway after having a play i do i have one or two questions that hopefully someone can answer on here.
Needless to say im still a little confused by the setting on the onboard computer, however just above the clock there is a speed reading which reads in Km/h. Is it possible to change this to mph at all ?
Can someone also confirm that the audio system i have is Audio 20 ? Would I just be able to swap this unit out for another command system, with sat nav and ipod connectivity for example.
thanks for your time.
jberks
I believe it can be changed but it would require a merc computer as its a UK spec setting to get around the fact that the speedo doesn't have any kph readings.
Yes you have an audio 20. Command can be fitted but I don't know how complex a task it is on a clc. To be honest an audio 20 with a tomtom is a better setup anyway. (overall, if you factor in cost and updateability, tomtom is about the best satnav - its not the market leader for nothing!)
I would think you should be able to add an MB ipod interface to your audio 20.
Alex M Grieve
Broom, Warwickshire
Needless to say I'm still a little confused by the setting on the onboard computer, however just above the clock there is a speed reading which reads in Km/h. Is it possible to change this to mph at all ?
My W211 (2003) used to give an option to toggle between kph and mph on the digital readout. I tended not to use mph in the UK as I preferred the analog, but used kph in the foreign and it was very helpful.
I am surprised that your more recent car can't do this too?
R171 SLK280, Smart R451, 997 C2S, R1250 GSA TE 40th, CBR600FP
The C's didn't have the option which is a great pity. I know they have cleared the speedo slightly by removing the KPH figures however it is annoying not to be able to pull up digital MPH. I use this quite a lot on my W211 however I would like it in the bottom display instead of KPH, I could then leave the navigation in the top display.
jberks
They can, but the kph readout is always there. You can get an additional switchable kph/mph readout in place of the trip computer or other function display but the KPH reading is static at the bottom.
In other countries I believe it can be switched to outside temp etc.
D
Dinalli
Cheers i will have to have a good look through the handbook to figure out how to do that.
Ive come from a Civic type R that had a digital readout, and really used to it, so was hoping i could change it easy.
thanks for the replies so far guys
www.ckinsurance.co.uk
