cleaning around spark plug area
SilverSaloon
w124/1994/om606
hi
my 107 has grime/gunk around where the spark plugs are - i would like to clean all this area up before i remove the old plugs and fit new ones.
any advice on how to do this - i dont want to damage anything.
also whats generally the cause of the gunk here? worn components or just build up over time?
thanks
derek
Myros
R107, S211, R170, C219
try this for a bodgit
get an old plug, hacksaw the insulator assembly off, making sure you dont create a hole where crud can get by. Also cut some threads diagonally into the plug thread with the hacksaw. Remove your current plug, fit the modified one, use a suitable wire brush attachment on a flexi-shaft from your electric drill to clean the recess, hoover it out, blow it out, and then remove your modified plug, which should have cleaned up your head threads as well in the process.
Should I patent this?
SilverSaloon
SilverSaloon
w124/1994/om606
get an old plug, hacksaw the insulator assembly off, making sure you dont create a hole wher crud can get by. Also cut some threads diagonally into the plug thread with the hacksaw. Remove your current plug, fit the modified one, use a suitable wire brush attachment on a flexi-shaft from your electric drill to clean the recess, hoover it out, blow it out, and then remove your modified plug, which should have cleaned up your head threads as well in the process.
thanks - sounds a good idea. i'll give that a go - i'm planning to give the 107 a quick service before i return it to the road. i plan to replace the spark plugs, clean the general area, adjust the timing, change the oil and filters.
turbopete
Spennymoor
another common trick, if your cleaning crud away so it wont drop down the plug holes when you remove the plugs is simply to wear a pair of goggles to protect your eyes and blast the crud out with a high pressure air jet. mechanics do it all the time.
Xtractorfan
S class
You've seen a mechanic wearing goggles .. a rare sight indeed.. its normally point the blowgun look the other way and blast..
wireman
lancashire
You could try a pressure washer, wet the area to clean with GUNK and let rip.
The plugs will need drying afterwards though.
turbopete
Spennymoor
i meant the air line bit, not the goggles bit! the goggles part was put in for the safety of others! :shock::shock:
turbopete
Spennymoor
id steer clear of that if at all possible. water is required to rinse gunk away. so many electronics under the bonnet, IMO water is the last thing you want under there
SilverSaloon
SilverSaloon
w124/1994/om606
i think i'll scrape off as much as possible with my fingers, then apply the gunk degreaser and then finally try the air trick. at the moment i'm not cleaning the engine bay (will do this at some point) - i'm just cleaning up that general area as i want to get the engine running nice and give it a service before i return it to the road. thanks
www.ckinsurance.co.uk
