Mobitechaz
- Jan 16, 2021
- c280
https://forums.mercedesclub.org.uk/index.php?threads/c240-key-locked-eis-or-a1-module.63474/
The thread above by OP "Michel" was most relevant to this scenario.
Client reversed polarity accidentally while installing new battery on 06 c280.
Upon initial scan there were numerous codes for CAN faults, most likely due to Battery.
Upon clearing codes, there were only two remaining, one code for central locking mechanism, the other ambient Air Temp (short circuit to positive battery), and 2 codes in the ABS/DSC for Steering Control Module alleging no CAN info from N73 or A1.
Following the OP's advice, I disconnected a fusible link and was able to get the key to turn in the lock cylinder and start vehicle. UPon starting, vehcile showing no alternator voltage. I suspect the ALternator voltage regulator has been compromised, and I'm ordering new VR.
Question is do these codes indicate a Front SAM (drivers or passengers side) issue? I've replaced all fuses and fusible links appear intact. Client reported some smoke when he crossed terminals, but i suspect that smoke was the alternator VR burning up. I didnt appreciate any melted or discolored fusible links.
Seems my situation is exaclty the same as the OP, but that post was 10 years ago, and I am not able to PM him. Thanks for a moment.
Mobitechaz, ASE cert german import
