Climate control unit illumination
hugsy
east riding
500sl/2005 w230 and 2004 ML350
Hi
I have a 1997 129 500SL and the 1.2w LED which illuminates the climate control unit when the side lights/headlights are on.The light is very dim and only stays on for about 25 minutes.If I then stop switch off the ignition and the switch it back on the light works again ,but then it switches off again after only 5/10 minutes.I have changed the LED (I even tried to find a higher wattage than 1.2 with little success) but it may be the led holder that slots in to the back of the unit.My Main Dealer says that Mercedes dont supply the little plastic bulb holder by itself ,I would have to order the complete Digital Climate Control Unit !!!!! Anyone got any suggestions?
bigasotonuk
Southampton UK
C43/55 AMG 1999 / C230K 1997
You call it a LED "bulb", in mine it is a normal incandesant lamp, which I expect that yours is too, just replace it as they discolour over time and drastically reduce the amount of light they emit.
H
hugsy
east riding
Mine is the unit with the oblong display
stats007
Hampshire
Looking
There are some cross-over cars but it should be the later digital aircon unit from 1996:
The unit gets illumination information from the instrument cluster via K1 - it's possible the signal is faulty if it's shutting off deliberately.
Najib
same here
Hello,i have the same problem,but my car is w124 300e 1992,i have the automatic climate control,if iam NOT using it then the light is working fine,just when i switch it on then it becomes the same story as urs.i tried the fuses the sensors but no luck,but mine slowly dims and then dies.
hopefully we ll get some help.
thank u all
