Climate Control Unit Lights
Bluegrass
W210 E320 Avantgarde 2000
Some of the lights on the selector buttons of my W210 climate control unit unit have stopped working.
As far as I can tell the functions still work i.e. the aircon is an obvious one but I'm not sure about the rest.I've taken the unit apart before to fix something else and the bulbs are very small.
Is it possible to change these?
I don't know if it's related but at the same time as the above problem the low fuel warning light stopped working.
Thanks.
Bluegrass
Bluegrass
Thank you Malcolm.
I'll have a look inside.
Myros
R107, S211, R170, C219
it might be tied up to
the multi-pin connectors at the back of the dash. Maybe one has worked loose , can't see how if it's not been played with but stranger things happen at sea.
Bluegrass
Bluegrass
I've had to take it apart a few times in the past couple of months to fix the pixels.
It's worth another look.
The cigarette lighter fuse had also blown at the same time.
