Hi Guys,
Recently acquired a CLK 220CDI Avantgarde (56 Plate) as a daily driver.
Have been looking into iPod integration and was looking at the kit from 'Command Online', which is £250 that allows steering wheel controls etc.
However, I'm now looking at using the Aux option as it's more cost effective route. I've checked my glovebox and can't see a connection but can see the pre-drilled hole, which leads me to think I need the following:
https://www.commandonline.co.uk/aux_input_w203.html
Would this be correct?
I haven't checked the trim panel near the door, but am I right to think the connector will be there? Because when I press CDC on the Audio20 unit is does says 'AUX Active'.
Finally, is there any way I could use a longer AUX cable, and have it feeded out near the gearstick or under the seat, so it's easier to control the iPod as I won't be able to control it via the main unit.
Thanks in advance!
Thanks in advance!
