Recently I had a problem with the electris seats, i decided to check all the fuses under the bonnet and in the boot I also disconnected the battery terminal in the boot hopeing that this would reset the system and thats where it all went worng.
I closed the boot after checking all the fuses in the boot only to find that now I cannot lock or un lock the car using the key thob.
However the incicator lights flash and the windows come down when i keep the unlock button depress and the windows go back up when I press the lock button on the key thob but just will not lock or un lock the car.
I have also noticed that the boot opening switch inside the car has stopped working as well, to make matters worse the emergancy key will not unlock the boot. when the key is inserted into the boot lock the botton can be pushed in but the key cannot be turned in any direction.
I suspect i may have put one of the boot fuses in the worng position but I can not get into the boot to check.
Can anyone advise as to how i can possibly get the boot open
my car is the 2000 model
