GilesCLK
I have a 2006 CLK 280 Conv which has the 7G Tronic auto box.
The car has 90,000 miles on the clock.
For the last 6 months the car would occasionally do a hard gear change and then stick in 2nd gear, however simply stopping the car, putting it onto park and turning the ignition off and then restarting it would cure the problem.
As of yesterday I can't get any gear other than 2nd, reverse or neutral, and there is a major judder when selecting any of them.
I have read that people have had numerous problems with these 7G's and that often the auto valve body replacement is required which is quite expensive.
1) Has anybody had the auto valve body replacement done ?
2) How much did it cost ? (MB have quoted me £803 for the valve + £380 labour + £133 for the fluid change - all incl VAT)
3) Did it work ?
4) Is there any way to re-set the gearbox ?
5) Is it worth getting MB to do a transmission oil and filter change first to see if that solves the problem, albeit if temporarily ?
6) Has anybody managed to get this work done for free if the car is out of warranty ?
Many thanks for any help.
Rgds
Will
3) Did it work ?
Rgds
Will
