CLK 320 brakes work but no bite
Discussion in 'Suspension, Steering & Brakes' started by Boofleman, Jan 28, 2019.
  1. Boofleman
    Boofleman Member
    10
    Jan 28, 2019
    Your Mercedes:
    CLK 320/2003/W208
    Hello. This is my first MBO Forum item.
    I've recently bought a very nice CLK 320 Elegance Cabriolet (2003). So far very pleased with it. It only has 70,000 on the clock and, looking at the history, seems to have been hardly used at all by previous owner.
    Now the brakes work but they do not seem to have the bite I think they should have. I also have a Skoda Octavia and the brakes on that are amazingly good. So that is my comparison.
    Further, when I do hit the brakes hard at slow speed (to see how well they work) I get a front end clonk.
    Looking through the wheels the discs don't seem to be scored and, the side I can see, looks like even area wear. From what I can see of the pads I would say they are about half worn.
    Any ideas would be appreciated.
  2. rifiki
    rifiki Senior Member
    200
    39
    Dec 29, 2015
    Worksop
    Your Mercedes:
    clk W209 Ponton 190
    Glazed pads, loose calliper? Had similar problem, disc on inside full of dents from rust spots(?). Car had been standing/little use.
  3. Wighty
    Wighty Senior Member
    5,191
    2,431
    Aug 4, 2016
    Your Mercedes:
    Welcome to the forum buddy . Have you checked the colour and level of the brake fluid , should look like champagne , if it's black that could be your culprit , because it absorbs water
  4. Oldspanners
    Oldspanners Senior Member
    312
    165
    Oct 30, 2017
    Your Mercedes:
    C CLASS 2004 C180
    A change of brake fluid is a good idea to start with as if its contaminated or has air in it it will effect the braking.
    If it hasn't been used in a while or frequently the pistons in the caliper could be sticking slightly.
    You may need to "exercise" them by taking the pads out one at a time and using a lever to stop it and push it back in when the brake pedal is pushed.
    As for the clunk it could be one of the front control arm ball joints.
  5. alexanderfoti
    alexanderfoti MBO Forum Supporter Authorised Forum Supporter
    10,697
    1,367
    Mar 25, 2010
    Dartford
    Your Mercedes:
    Yes, all of the above.
    Brake fluid that is very old gives a wooden feel, and caliper sliders that are stuck give poor braking feel too.
  6. OP
    Boofleman
    Boofleman Member
    10
    Jan 28, 2019
    Your Mercedes:
    CLK 320/2003/W208
    Hi. Many thanks to all for quick and very helpful response. I will certainly get the fluid changed and the calipers checked.
    Concerning the fluid - where is the reservoir? Can't see it in engine bay or in the book !!
    Can't see a dip stick either - except when I look in the mirror !!!
    Wighty and alexanderfoti like this.
  7. Wighty
    5,191
    2,431
    Aug 4, 2016
    Your Mercedes:
    Brake fluid reservoir will be under black plastic , on my E class it's back left of the engine bay as you face the engine from the front .
    yours "may" be in the same place ?
  8. EmilysDad
    EmilysDad Senior Member
    6,762
    920
    May 8, 2012
    Bury Lancs
    Your Mercedes:
    R320 2007
  9. GordonTarling
    GordonTarling Senior Member
    84
    17
    Jul 25, 2004
    Grantham, Lincs.
    Your Mercedes:
    2007 E63 AMG Estate
    First thing I'd do is fit new OEM brake pads - someone may have fitted cheapies and best to start with known quality parts.
  10. OP
    Boofleman
    Boofleman Member
    10
    Jan 28, 2019
    Your Mercedes:
    CLK 320/2003/W208
    Many thanks for your advice.
  11. OP
    Boofleman
    Boofleman Member
    10
    Jan 28, 2019
    Your Mercedes:
    CLK 320/2003/W208
    Good advice. Just ordered a new set. Thanks
  12. OP
    Boofleman
    Boofleman Member
    10
    Jan 28, 2019
    Your Mercedes:
    CLK 320/2003/W208
  13. OP
    Boofleman
    Boofleman Member
    10
    Jan 28, 2019
    Your Mercedes:
    CLK 320/2003/W208
    Found it !! You were spot on. However, at the far back of the engine there is a stubby little plastic dip stick in a tube. Any ideas?
    Wighty likes this.
  14. alexanderfoti
    10,697
    1,367
    Mar 25, 2010
    Dartford
    Your Mercedes:
    If its red, that is just the cover.
  15. OP
    Boofleman
    Boofleman Member
    10
    Jan 28, 2019
    Your Mercedes:
    CLK 320/2003/W208
    Many thanks indeed. I have ordered new brake pads and will do the fluid change when fitting them. Will also check for sticking calipers.
    If the control arm ball joint is worn how could I tell? Would there be any visual signs?
    Many thanks
  16. EmilysDad
    6,762
    920
    May 8, 2012
    Bury Lancs
    Your Mercedes:
    R320 2007
    Probably not. Lift the wheel off the ground & try to move the wheel left/right by hand, feeling for any clunks knocks etc
  17. OP
    Boofleman
    Boofleman Member
    10
    Jan 28, 2019
    Your Mercedes:
    CLK 320/2003/W208
    No its not. Its black and when I pull it out it is about 8cm long. Fluid on the 'stick' is clear and light - hydraulic?
  18. OP
    Boofleman
    Boofleman Member
    10
    Jan 28, 2019
    Your Mercedes:
    CLK 320/2003/W208
    I'll try that. Many thanks for your help
  19. EmilysDad
    6,762
    920
    May 8, 2012
    Bury Lancs
    Your Mercedes:
    R320 2007
    Sorry ... I don't
  20. John Laidlaw
    John Laidlaw Senior Member
    18,149
    4,550
    Nov 15, 2013
    Wirral
    Your Mercedes:
    UnMercs BMW i8 Volvo XC90
    Surely the ATF what’s never been changed?
Share This Page
