clk 320 R 1998 removal of rear seats
stevebike
Can anyone give me some advice on how to remove the rear seats, to enable me to adjust the handbrake cable
Many thanks
Steve
It just lifts up, there might be 2 catches just below, nothing else
Miffy
Bromley, London
CLK 320 CAB Elegance C208
yep, grab the seat from the front edge and pull up, its held down by 3 spring clips at the front alone
stevebike
Hi every one what is the easy way on how to fit brake shoes for the foot brake .To the rear of my clk320 1998
do you have to take the stub axel off to make it easy to fit them it looks a bit nasty
thanks steve
stevebike
Rear brake shoes for handbrake
Is there an easiy way to fit rear brake shoes for the footbrake on my clk320 1998.Do i need to take the stub axal off to make it easiyer.It looks nasty
thanks steve
Its fairly easy to do, you have to unbolt the caliper and put too one side, back off the parking brake adjuster, take out 1 screw from the drum part of the disc, knock the disc off, then make a note of where the holes that the springs are in on the shoes and remove.
The link here covers it apart from changing the shoes.
http://forums.mercedesclub.org.uk/showthread.php?t=26764
http://www.detali.ru/cat/oem_mb2.as...GA=722.607&CT=F&cat=45Y&SID=42&SGR=045&SGN=02
http://www.detali.ru/cat/oem_mb2.as...GA=722.607&CT=F&cat=45Y&SID=42&SGR=145&SGN=05
The picture shows the adjuster and you use a flat screwdriver through the hole to turn it with and up or down movement
At this stage you should think about changing the rear disc if worn, it will save you have to do it all over again.
