Hi every one what is the easy way on how to fit brake shoes for the foot brake .To the rear of my clk320 1998
do you have to take the stub axel off to make it easy to fit them it looks a bit nasty
thanks steve
Is there an easiy way to fit rear brake shoes for the footbrake on my clk320 1998.Do i need to take the stub axal off to make it easiyer.It looks nasty
thanks steve
Its fairly easy to do, you have to unbolt the caliper and put too one side, back off the parking brake adjuster, take out 1 screw from the drum part of the disc, knock the disc off, then make a note of where the holes that the springs are in on the shoes and remove.
d:class automotive are specialists in automotive interiors and upholstery. From Mercedes and modern cars to custom and classics. Tel: 01483 722923
Email:info@dclass.co.ukWeb:www.dclass.co.uk
