alicampbell
- Apr 29, 2007
I have just bought a 2002 CLK 320 and I noticed a slight leak from the bottom radiator hose, after a day or so the warning message appeared 'coolant level low'. After inspection I saw that the large hose coming out from the bottom of the radiator was leaking slightly due to the fact that the clip that holds the hose in place was not seated well in the retaining grove and the hose was actually starting to come out of the flange on the bottom of the radiator manifold.
I pushed the hose in as far as it would go, which was not as far as I would expect, and adjusted the clip to what looked like the correct position. After a short test drive the coolant level warning came on again and when I checked the problem the hose had completely blown off and all the coolant had drained out. As luck would have it this happened outside a petrol station and I was able to push the hose back on and fill the coolant again. This time the hose seemed to locate much better in the flange and I replaced the clip which I must say still doesn't feel very secure. The clip only covers about 75% of the circumferance of the hose and locates in two very shallow goves in the plastic manifold, is this normal or is there something missing?
Since then I have done about 50 trouble free mile but I am not filled with confidence. Does anyone have any similar experience or advice on how to avoid this.
Many thanks...
Many thanks...
