Clk 430 boot entry problem
Wallywells
Com 1999 430
Removed battery for charging but key will not open boot.can I get
in via rear seats.i don't know if it's possible to release seat clips from inside car
robparker
Taunton
Not without breaking stuff
W
Wallywells
Com 1999 430
Reluctant to force key to much.sprayed with WD-40 but snow here stops further investigation
robparker
Taunton
The boot button should always be flush with its surround, not pushed in. Normally you would turn key and push button together, but obviously your lock is seized up. You might get there with persistence and lube
W
Wallywells
Com 1999 430
Thanks for replying.ive been told there should be a battery pole under bonnet.when it stops snowing i will remove the six inches of snow from bonnet and check.once again thanks for responding
Yes there should. It will be in a little black box on the passenger side inner wing by the strut top mount and the box will have a red + on it (assuming its the same as my 210).
ajlsl600
france
i had that on clk once , lifted rear first aid kit and tray,,do you have that? and dremelled out enough plate to get my arm in and yank on seat lock cable. after which i never lock down the small side of rear seat, i also fixed rear lock barrel and now oil them on regular basis .was F annoyed at the time ,but my fault unless you want to blame benz for putting batt in boot.
splitshift
central scotland, for now !
Clk 200 kompresser convertable, 2001 Citroen c2 Audi A3, jaguar xj6 and big scanias !
Under bonnet post, box whatever, should work yes, BUT! From painfull previous experience, do not do work on convertible roof , because the boot will not open if roof isn’t at home position ! I know it’s a bit of topic but had I known first, !!!!
sonic
Staffordshire
E350CDI, SLC250d, FJR 1300
I had the same problem on a 2001 CLK which I bought 3 years old. I just happened to check if it worked, it didn't.
Rang MB who said use loads of WD40 on it, but it didn't work.
MB said bring it in & we will change the lock free of charge. Out of warranty so very nice of them.
Frontstep
T210 320cdi
Lubrication with WD40 is a waste of time a proper penetrating oil is needed to free it off and if you have one an old electric headless toothbrush inserted afterwards into the key slot and turned on works wonders.
A 50/50 mix of acetone and ATF is probably about the most effective penetrating oil you can get. It will separate when left so needs a good shake before use.
peterws1957
Lancashire
Yep - you need WD40 silicone grease jobby but acetone/atf is best as LostKiwi says.
Frontstep
T210 320cdi
Something I would normally use but be careful around plastics and bodywork.
You then want a dry lubricant as grease attracts the muck which will gum it up again.
www.ckinsurance.co.uk
