CLK Battery charging using a trickle charger
MykhailoM
Manchester
Mercedes Benz CLS W219 Grand Edition
Hi fellow Merc owners.
Will it be OK to charge a battery in Mercedes CLK 220 CDI 2.1L without disconnecting positive & negative contacts or will I be better off just disconnect the ground (-) only?
Mykhailo
grahamcol
West Midlands
2001 SLK230, 2007 CLK220 CDI
Hi and welcome.
You should be fine as long as you use a modern electronically controlled charger such as a Ctek or similar. I use one very often on both my C class and SLK and have never had a problem.
mikestrivens
Stockport
Most of us keep a Ctek or similar optimiser permanently connected when in the garage. It saves a great deal of faf when you come to use the vehicle.
'93 500SL-32, '01 W210 Estate E240, 02 R230 SL500 (Malcolm Spec), 04 Smart Roadster Coupe
As above. Two of my cars have trickle chargers permanently connected all winter. Malcolm always had his on a trickle charger when it wasn't in use.
rifiki
Worksop
CLK W209 W121 190B
Have hot wired Ctek to my W209 CLK. If you use the ‘recon mode’ disconnect the battery.
Prestige Motor Group is Hertfordshire's Premier INDEPENDENT MERCEDES BENZ SPECIALIST. We offer a service exceeding Main dealership expectations and HUGE savings on Main Dealership Prices. WE BEAT ANY GENUINE QUOTE! Prestige Motor Group pride ourselves on delivering excellent customer service as we believe the customer and the Car deserve the best.
Tel: 01462 672458www.prestigemotorsofhertfordshire.co.uk/
