CLK rear wheel arches rust
ash1212002
Coventry
clk 200 coupe kompressor auto 57 plate
Hi looking to buy another CLK on an 09 plate with 55k on the clock
Unfortunately there appears to be rust on the rear arches, Pics attached
I understand this is quite common on the CLK’s
Unsure how bad the rust is, anything I can do to prevent it from spreading or slowing down the rust?
Or shall I avoid purchasing the car?
nick750
Rhyl N. Wales
2007 220 CLK CDI and Kawasaki Z1000sx
Mines an 07 and exactly the same waiting for some nice weather and will address, there is a good thread on here on how tho fix .
A
ash1212002
Coventry
Hi Nick
Willing to give a diy go at this myself, could you kindly point me to the link?
Cheers
Any decent bodyshop would soon have that sorted - Our SL was the same and is now immaculate again.
Having just done some under car rust converting and black hammerite on both my E and Clk , both 2009 ( the Clk had more rust , some of which was on the rear of the car underside . If you are buying the car I would seriously want to see the rear underside on a ramp , use any rust as part of your negotiating deal .
umblecumbuz
Wales and Gozo
I did Malcolm's method on my SLK.
It was easy:
Rub down and treat the rust around the return lip, using your chosen method. I primed, then applied smooth Hammerite, being careful not to paint further than the lip itself. Obtain some plastic beading from a Mini specialist supplier - several advertise on the net (remember the original Minis? They had external seams and these were covered with a fairly stiff plastic channel, or beading).
Liberally coat the repaired lip with Waxoyl. Warm the Mini beading in a bucket of hot water to soften it, and curve it to the shape of the bodywork. Roughly cut to length. Apply over the Waxoyled lip and trim to exact length.
It looks like an Oem finish when applied, will not dislodge even under pressure washing, and will not rust again.
Another thank you to departed Malcolm.
A
ash1212002
Coventry
It was easy:
Run down and treat the rust around the return lip, using your chosen method. I primed, then applied smooth Hammerite, being careful not to paint further than the lip itself. Obtain some plastic beading from a Mini specialist supplier - several advertise on the net (remember the original Minis? They had external seams and these were covered with a fairly stiff plastic channel, or beading).
Great - do you have a link you could provide where i could get the beading from as I am not familiar with what I am looking for
JBell
Torquey
C350 CDi Estate (GAD Edition)
You will need to clean the arches out properly, there will be loads of dirt and debris behind the lip all round, get the wheels off and get scrubbing before you try any fix for the rust
andy talbot
bratfud
W204 2012 2.1 estate
Thats not rusty ........this is
great thanks!
So once I done what I need to remove the rust this goes over the inside lip of the arch? how is it secured to avoid from coming off?
It just clips on. There is s black rubber version aswell but be careful of that version as it has steel 'teeth' which could scratch the paint underneath back to metal which will then rust.
umblecumbuz
Wales and Gozo
There is also a black version thst is identically made to the chrome one above - with no 'teeth'.
Your choice, but I used the black version and it looked 'right' - and unobtrusive.
Depends whether you like bling or not.
The Miniclub website might be worth an email before you do the job.
A
ash1212002
Coventry
  • #18
I think i would prefer the black will message the ebay seller to check if they have the black version in stock
McDonald
Surrey
SL500 2004
Alistair, How much did it cost to have it done professionally? Mine are just starting to deteriorate and I'd like to get it right up to snuff. I will be taking to a bodyshop I've used before, but always good to have a figure in mind.
Our SL cost £880 but we also had a couple of other bits done (rear spoiler and front number plate surround).
www.ckinsurance.co.uk
