clk seat window and door mirror fault
tris793
HI, i have a W reg clk 230 which i have owned now for a few months. All works fine except for the drivers side seat, window and wing mirror fail to work.
I have had them working by disconnecting the battery then reconnecting but it only last a couple of days before they all stop again.
I have also had the door card off checked all the wires to the control module and changed the module for a 2nd hand one which i bought. once again it worked for a short while then stopped.
When it does work it can work in short pulses or just in a fluid movement. If any one could help it would be much appreciated.
Cheers, Tris.
Helo and welcome, your fault still points to the controller, I would check the coding of it. You have this done on STAR.
The mirror position and heating, seat position and windows are all CAN operated, and the cat may not know that it has them
