CLK Sun Visor
richardjcf
Hi
I have managed to snap off the mirror flap cover from the passenger side sun visor from my CLK (209). Is it possible to replace the flap or is it a full new visor? If it is possible to replace the flap is there a part number for it?
Thanks for your help
R
richardjcf
Thanks for your help. I will start to contact the places you suggested.
Thanks again
teddycatkin
cheshire cheese country
Hi Richard-- if only one "peg" has snapped it can be mended by carefully inserting a small thin screw in its place and then sawing the head off at the right length.
I have a pair of new W210 E class mirrored visors in grey leather -but am not sure if they fit the CLK ?
djb
uk
Hi
It might be posible to make a new pin, by using a small nail.
drill out base of broken one & clip appropriate size nail, re insert & glue.
doh should read to end of posts first!!!
did similar to an expensive marine fridge, when the freezer flap was snapped off.
That works well, and I have done hundreds of the flaps that we used to get on the older TV set, just by drilling out an using a thin nail
R
richardjcf
Thanks for all your suggestions, drill and glue here I come:shock:
