CLK W208 Windscreen trim
cocothecat
Cardiff, South Wales
Focus, CLK 230, 911, Spitfire MK II
You know the bit of trim over the windscreen on the clk where are the bolts for that hidden? Under the panel inside? Mines come lose somehow and I think it just needs to be screwed back...
C
cocothecat
the one left and right of windscreen on a coupe ill try get a photo if that makes it easier? I took internal trim off and could not locate the screws!? :/
C
cocothecat
Its the bit i posted up before about the seal not making contact, the reason as I found out today going down the M4 is the fact its lose! and almost came off...
see what i can find for you
Can I have your Email address please and I will send the details
Details sent :D
C
cocothecat
got it, i assume if i pull off the old rubber seal i can re attach it? just want to know before i go out and fix now
As it says you may need to replace any damaged clips or seals, is it possible that just the clips are broken, this is allowing it to not press down on the rubber seal
C
cocothecat
Malcolm you are a legend! If it was not for the fact the wife had the camera I would have taken photos of the job in hand.
Putting the rubber back on was a pain until I re-read the instructions ;)
Turns out there was a missing screw in the first step and a missing washer at the top, replaced them with bits I had in the shed and job done!
