Clk w209 licence nr plate not working
todea
london
clk200
Hi all,
got the car with this problem and altough the seller told me it's just the bulb..it's not!i have checked all the wire's under the boot lid cover and seem's all fine.do some research and could believe it's the SAM unit.powered from the tail light they do work..any advice would be welcome:)
I do not have much on the 209 but I have sent a general paper on them,,,if you need something specific then maybe I can help
T
todea
london
clk200
do you know if there's a way to have the unit tested?thanks
davidsw
cornwall
Jaguar XKR ,Jaguar S-Type, Porsche Boxster S
I had a similar problem with no. plate light .Mine was flashing on and off every second or so .New rear sam was needed after star highlighted the cause .
I will check later in the day on what David said and the rear SAM
T
todea
london
clk200
Problem solved by the local garage.Somethng with the wire's
Thanks all!
