Clk230k 2000 Digital Display
ONEMERC
Hi there,
Is anyone able to advise how to get to the rear of the display on my CLK so that I can check connections to a dodgy digital clock.
the instrument cluster pushes out from the rear,nothing holding it other than a tight fit. there are tools so that you can pull it out.
The fault is poor connections that need packing out with wedges.
Malcolm
O
ONEMERC
Thanks for that - but how do you get to the back of them to push them out???
Just take out the panel from under the dash.
The cluster will be tight and it will need a hard push,from one side or the other,once it starts to come its easy.
malcolm
I was going to look for your guide to put into the 'how to' now I have the link I will copy it in. :)
The actual fix of the digits can be put up later, I would love to get my hands om one.
When I get Pipemasters I can photograph that but it is a different fault.
Malcolm
O
ONEMERC
Thanks - Help Much Appreciated!!!
m8bgb
New Registration
contact your nearest MB dealer... there ie a factory recall on these and the S class instrument cluster...they are replacing them FOC
The problem dash is on a CLK which is not covered by the S class repair for some bizarre reason :rolleyes:
O
ONEMERC
Has Anyone Managed To Get This Done As A Recall On A Clk?
