Clk230k Braking System
STOPYAWNING
New Registration
Hi, Can Anyone Help?, I Own A 1999 Clk230k Recently I Noticed The Braking Is Very Poor Therefore I Changed The Front/rear Discs/pad. After Almost 500 Miles The Brakes Are Still Very Bad As The Foot Pedal Touches The Floor Aswell As Abs Light Comes On, Any Solutions
Al
jamesmc
Algarve, Portugal.
W208 CLK230K Cabriolet
Was the brake system worked on/split prior to the problem that caused you swap out the discs/pads in the first place? Because if so, air in the system would cause the symptoms you have mentioned.
If you pump the brakes does the pedal start to come up away from the floor.. ie. less soggy/soft.
Cheap first checks are... check fluid level, bleed brake system, check level again, test.
www.ckinsurance.co.uk
