clk240 srs light
LOTUS53
CLK240 CONVERTIBLE AUTOMATIC V6 2005 M112 ENGINE
HI I have a 2005 clk240 convertible .Three days ago I started getting the bouncing door lock issue on the drivers door.I now have the SRS light on permanently.Is this a coincidence or does anyone know if these two faults could be linked
Alec
Coincidence. The bouncing lock is a physical spring in the door.
L
LOTUS53
OK thanks for your reply.Under the drivers seat I have a large yellow block connector and a small 2 wire yellow connector .The latter has the wires cut or broken .Can anyone tell me if these are SRS connectors and why would the 2 wire connector be disconnected.There is no sign of any wiring having been connected to the 2 pin block so I am guessing this is not part of my fault but has been cut in the past
mersum1es
Finland
Yes, yellow is used for SRS stuff to recognize it. Perhaps you have seat sensor (or wires going inside the seat) gone bad and previous owner used chinese emulator to keep the light off.
So you bought a car with SRS on or it just appeared?
L
LOTUS53
no it came on 2 days ago l have had car about a year now
Not unheard of for wires to break when the seat us pushed back, especially if something is under the seat.
www.W140.co.uk&www.r129.co
