CLK63 AirCon Oddity Please Help
Discussion in 'Electrics, Vacuum, Ignition and ECU' started by David63, Jul 13, 2019.
  1. David63
    David63 Member
    13
    Jul 13, 2019
    Your Mercedes:
    CLK63
    Hi all, I am a new member with an odd problem on my CLK, quite simply I have warm air coming out drivers side only when turning on the air con. I have read many issues but non on the CLK as quite a few Mercedes member mention the duo valve issues but I am quite sure the W209 does not have these valves so I really am stumped so I am turning to you guys in the hope someone recognises this problem on my CLK. Thanks in advance for any help or advise given.
  2. AJD
    AJD Senior Member
    5,862
    1,553
    May 31, 2015
    Suffolk by the Sea, UK.
    Your Mercedes:
    2012 W204 Sport ///AMG Line 4dr Auto, Obsidian Black, Light Grey Faux Leather. And no AMG badges !!
    Hi David, can't help with your problem but welcome to the forum. What a great car you have there :)
    David63 likes this.
  3. Blobcat
    Blobcat Moderator
    13,558
    2,948
    Near Grange Moor (not Wakefield...)
    Your Mercedes:
    R171 SLK280 3.0, Land Rover 110 County SW
    Hello and welcome
    Do you have separate temperature controls for passenger and driver?
    I’m thinking it’s a flap issue, which might be able to be diagnosed on star (Mercedes diagnostics)
  4. rf065
    rf065 Senior Member
    2,593
    140
    May 30, 2007
    Grossbritannien
    Your Mercedes:
    There is a procedure to reset the flaps on the CLK, I had to do it when I had mine. You would need to search for it as I cannot remeber how it's done. Worth trying first as it's free.
    David63 likes this.
  5. OP
    David63
    David63 Member
    13
    Jul 13, 2019
    Your Mercedes:
    CLK63
    Thank you all for your kind remarks and a nice welcome, maybe I should of specified that I did go through the reset procedure after finding it on another forum but maybe I need to take it to a Mercedes specialist to have it diagnosed on a Star. The guy who takes care of my lady is an ex Porsche specialist and understandably he is unsure, I didn't want a Mercedes stealer look at her as they charge stupid amounts of money when I get prices for my 63 and moreover you do not get value for money when it comes to diagnostic or servicing prices. Its not about penny pinching as you cannot have that view with these types of cars its more about value however, maybe it will just end up there or if someone in the N.E. England namely Newcastle who cares about what they do. But thanks again for your suggestions and I look forward to being a member of this great forum.
  6. Uncle Benz
    Uncle Benz Senior Member
    2,490
    681
    Mar 31, 2006
    West Sussex
    Your Mercedes:
    Mainly Mercedes
    IT makes no difference that it is an AMG when it comes to the AC. It is the same as the optional climate control on other CLK. Off the top of my head it sounds very much like a flap stepper motor fault on the drivers side. Star refers to it as air blend flap, and with the machine you can motor the flap and watch the hall counter value to check if the flap is actually moving. Comparing the action to the other side will pinpoint the fault. Sadly stepper motor failure is common, usually undetectable other than with Star machine. Plastic drive cogs also can break, but these are easier to spot by a regular rhythmic clicking sound from behind the dashboard. The driver's side air blend motor can be replaced without removing the upper dash, just by stripping out the lower part and working in the footwell. The parking brake needs to be moved aside. It is still a job not for the feint of heart.
    One wot I was doing the other day. This was a defroster flap motor failure, caused by a silly vent mounted cup holder. It broke, a bit went down the vent and wedged in the flap.
    [​IMG]
    Blobcat likes this.
  7. Uncle Benz
    2,490
    681
    Mar 31, 2006
    West Sussex
    Your Mercedes:
    Mainly Mercedes
    Here's one where I was just doing the blend flap motor, driver's side. That actually looks worse doesn't it!
    [​IMG]
    Blobcat and David63 like this.
  8. OP
    David63
    David63 Member
    13
    Jul 13, 2019
    Your Mercedes:
    CLK63
    Thanks kindly and WOW that looks insane and one well beyond me I guess I am looking for a good Mercedes Independent in or around Newcastle Upon Tyne so if anyone can recommend one this would be a start as work like this carried out by the Stealers would be so expensive. So if anyone can point me in the direction of a recommended Indy.
  9. OP
    David63
    David63 Member
    13
    Jul 13, 2019
    Your Mercedes:
    CLK63
    Just went out today and now there seems to be a low pitched scream if that makes sense, maybe this has been on before and I did not hear it as I had the radio off today so it was apparent, so not sure if this means anything.
  10. OP
    David63
    David63 Member
    13
    Jul 13, 2019
    Your Mercedes:
    CLK63
    Low pitched scream when turning air con on not just all the time sorry.
  11. Uncle Benz
    2,490
    681
    Mar 31, 2006
    West Sussex
    Your Mercedes:
    Mainly Mercedes
    Does it sound like a squirty whistle? Like an astmatic mouse? Low refrigerant usually causes that
    David63 likes this.
  12. rf065
    rf065 Senior Member
    2,593
    140
    May 30, 2007
    Grossbritannien
    Your Mercedes:
    Sounds like you have a leak, or at least need a regas.
    David63 likes this.
  13. OP
    David63
    David63 Member
    13
    Jul 13, 2019
    Your Mercedes:
    CLK63
    If it was leaking or indeed low gas would this account for air con working on the drivers side only ?
  14. Uncle Benz
    2,490
    681
    Mar 31, 2006
    West Sussex
    Your Mercedes:
    Mainly Mercedes
    I can't guarantee it, but it might be worth having an AC service first. Lots easier than pulling the dash apart.
    David63 and Blobcat like this.
  15. OP
    David63
    David63 Member
    13
    Jul 13, 2019
    Your Mercedes:
    CLK63
    Thanks, that makes sense its better starting with the easier options, I will get it serviced and re-filled this week and report back. Thanks for all who helped.
  16. davemercedes
    davemercedes Senior Member
    2,400
    606
    Jun 15, 2012
    Worcs
    Your Mercedes:
    2007 Merc 220 CDi Est Auto Av
    David63 likes this.
  17. OP
    David63
    David63 Member
    13
    Jul 13, 2019
    Your Mercedes:
    CLK63
    Thanks kindly, I have paid and booked mine in. Great to be part of this forum so thank all for you help and I will report back with hopefully good news.
  18. Rory
    Rory Senior Member
    4,731
    91
    Feb 8, 2005
    Cheshire, UK
    Your Mercedes:
    2005 C270CDi Avantgarde Estate
    How warm is it? I've had my car since it was a few months old and I've never been happy with the a/c in that it never felt 'properly' cold, but it always seemed to just about cope almost as if it's adjusting itelf based on hot it is outside (the system in my car shouldn't do that - there's no sunshine sensor). It's been regassed several times and last year the condensor was replaced.
    I happened to notice this year that right centre dash vent was more tepid than cold. On hot days I've taken to shutting the right vents and having the left one blowing at me. Checked the temps and got 8C from the left vent and 11C from the right - I was surprised at how low the difference was, it felt more than that.
    David63 likes this.
  19. OP
    David63
    David63 Member
    13
    Jul 13, 2019
    Your Mercedes:
    CLK63
    To be honest I cant remember it ever being ice cold and wife just bought Peugeot 208 and hers is so cold and I know for sure mines not that cold. I am having mine re-gassed but I am convinced it wont fix it but I suppose I have to start somewhere, my left side centre vent does not quite hit me so thats even more frustrating, maybe Ive worn it out as its on all year round, I will report back as I am sure there are many CLK out there with this issue.
  20. Blobcat
    Blobcat Moderator
    13,558
    2,948
    Your Mercedes:
    You don't wear out AC by using it all the time, you lose gas if you don't use it as the seals dry out and the gas escapes.
    I can get 5' in mine quite easily - I have a slightly noisy fan but not worth investigating yet
Share This Page
