CLS 2007 Mirror lens and LED
Zoro
North west Peninsula
I managed to break the driver side mirror lens backing out of the garage. It was a bad day and I have only myself to blame. All still work well except the LED which is dead. Can I obtain a new LED? I think I am good enough with my hands could I change the lens myself, or is it a garage job? Please could you explain how to dismantle the mirror! The mirror on the CLS turns on a pivot and there are no visible parts when fully flexed. Many thanks for any help. Sorry I may have posted originally under the wrong section
Z
Zoro
  • #2
Do I take it that no one has any previous experience in dismanteling the mirror on a CLS? :-( It looks like a trip to the local MB agency.
Did not see the post, the LED unit is around £17 from MB and easy to fit
Z
Zoro
Malcolm, thank you. I went this morning and got one. it is £24.40 including the VAT. Despite my encouregement ;) the gentelman from the parts department certainly was not going to part with the secret of how to dismantle the housing to change the blinker unit. Most of the threads talk about lifting a clip in the flexed position but the CLS like the S and the new CL the housing is closed and on a pivot, the only way I suspect is to go behind the mirror but what then? Any advice would be very much appreciated. thanks again
I will post back on this for you
Chas
Scotland
S320
This might help, I used it to find how to replace side mirror led on S CLASS
http://forums.mbworld.org/forums/showpost.php?p=1221277&postcount=1
Z
Zoro
Many thanks for your help. The mirror in the pictures are different to the CLS mirror and the new S. I am convinced that I may need to go behind the mirror to unclip something. What I need to know which part of the mirror housing I need to lever off (or is it the mirror it self? How?) to get access to the blinker unit. I am grateful nevertheless for your suggestion.
Ellsy Tanners
Mars
Hello,
The miror glass pops off, using a plastic wedge or screw driver, then the casing will be able to be dissmanted by unscrewing the torx screws , first take of the adjustment motor, again torx screws.
Hello,
Thanks this car is too new for me
Have they done away with the wire clip at the top
Ellsy Tanners
Mars
On the cls they have, its poped on at serveral points around the motor.
Z
Zoro
Hello,
This is great, many thanks I will have a go at the weekend and report back. Fortunately I have a set of torx screw drivers. I hope the "popping" of the mirror goes well :)
Much appreciated
Z
Zoro
Hello,
Hope no one is going to need this but if you do here it is how
It took me 30 minutes to do:
The most critical part is levering the mirror off. If one flexes the mirror in the housing it is easy to see the plastic lips which holds it onto the mirror motor disc View1
The mirror motor comes off taking 3 screws all torx number10. View2 and the rim of the mirror housing can be taken off by removing 4 further screws the 5th screw is in the background and holds the folding mechanism of the mirror View 3. By dislocating the outer housing one can then access the blinker which is held by two screws. unplug the electrical supply. it can go back only one way View 4
Many thanks for all the help
Hani
Will post the pics when I have figured out how. sorry
Ellsy Tanners
Mars
Great post, it will be very helpfull to others, its offen difficult to explian to someone without pictures, cheers
Stevemarsh423
Dorset
Mercedes CLS320
Thanks Zoro, just used pics to give me the confidence to fix my indicator.
Thanks for your time
Steve
