cls window refit question
gary sweet
wolverhampton
2005 cls 320cdi
hi all.recently had a window regulator problem.cable snapped.ive managed to fix it via a post on here.used a bike brake cable and a few crimps.did the job a trick and saved hundreds.my question is how do I refit the window and get it clamped in properly?is there a specific way to do it or is it just trial and error.pillar less glass looks great but as no guide for the glass to run in I need a pointer.many thanks in advance
I do have the replace cassette info if you would like it
G
gary sweet
wolverhampton
2005 cls 320cdi
sorry to be a bit dim but how do I receive it?via email or directly on here.again thanks
Email address please
OK you can edit out the address as sent
toolbox
Ireland
cls
Television or anyone,
The regulator on my cls 320cdi year 2007 has been playing up recently
This was my own fault as I tried to open the window several times when it was frosted closed. Since then it was squealing a lot, and today it packed in. I can hear the motor turning, but window not moving. Can hear the cable grinding also.
So looking for the following
1 how to remove the door card
2. How to replace the regulator.
3 can the unit in there be repaired, or should I purchase a new one.
Any help would be appreciated.
Can you PM me with your Email address please.
I have sent it.
