CLS window squeak
Rotorhead500
Very South Devon
Used to have a C63...
Morning all,
Not had cause to use passenger front window much, but on the occasions I have, there is quite a squeak being produced on the downward travel.
Its quiet when I put it up.
It even happens briefly on the short bit of travel during auto-drop when you open that door.
I am dreading its the infamous regulator playing up, but.....? :neutral:
(Was still evident after a couple of operations last week, whilst there was plenty of water about.
Could it be the glass rubbing on the felt window seal on the top of the door panel
AlastairD
Birmingham
2004 S211 E270 CDi Elegance 100k+
I've got the same issue....
http://forums.mercedesclub.org.uk/showthread.php?t=119112
I've gone as far as soaking the whole window in WD and it still squeaks, I really believe its something inside the door, a mechanism or a runner and nothing in contact with the glass at all.
To back up my theory when I did spray silicone inside the door it did stop for a while.
Next step for me is to get the door card off when I get a bit of spare time.
whitenemesis
CLS55 AMG '05
Curious.. My front passenger window has acquired a squeak. Well, more of a screech really. Only on the way down, up is totally silent. Even more curious is that it only does it if the car is hot, as in sat in the full sun. First thing in the morning or at night it doesn't make a sound!
Then it is door card off time to spray some PTFE in the cassette
If you would like the door card instructions I have them to send out.
Rotorhead500
Rotorhead500
Very South Devon
Thanks gents.
Mine is the same as Whitenemesis in terms of symptoms, def a screech. But not weather, heat or time dependant!
It goes in on Thursday for them to look into (literally) - hopefully under warranty!
whitenemesis
CLS55 AMG '05
Please report back on what, if anything, they find?
A screech to me sound like the motor bearings, the window lift is not going fast enough to screech
That's the normal sound I am told by owners before the Reg starts to eat itself, did another one lunch time today, seems to be a weekly job now......
ThinkPad
London
E W212; C W204
Is it just a coincidence that they are all passenger side!
I was just about to re post Colin :D the only other bit that goes as fast as the motor is the bearing on the regulator where the motor 20 plugs in, will lubricating help I wonder at this point
m.mycat
Its the cable that frays and then snaps Malc, it wraps itself around the motor drive, don't think lubing any parts will help........
b1g1an
CLS55 AMG
Did a drivers side one today!!!!
Mine was a driver's side one too, done under warranty, although mine was because of a rattle at the top of the door only when the window was right up, no screech. Noticed the driver's side rear was a bit noisy today when winding it up or down along with a clonk when getting to the bottom so will get that looked at too.
Forums are full of when not if stories of failure and like others have said they seem to be a stock item at the dealers and there's only one reason for that.
Rotorhead500
Rotorhead500
Very South Devon
Gut feel says its the regulator - had to laugh when dealer chappy said they'd need her in for 2 days in case they need to order the part in!!!
They do need to learn ;)
AlastairD
Birmingham
from another forum......
"kaos_cls500
I had this problem I opened the door panels and noticed that the wire that pulls the window is somehow causing the squeak. so I greased every moving part and it did work, but make sure that you put your hand deep inside the frame.
note: oil did not work"
better get me spanner out.
Royston59
Surrey
2014 CLS 350 CDI AMG Sport & 2014 C220 CDI AMG Sport edition (Wifeys)
IMO fom personal experience it will be the regulator no doubt....MB warranty suggests lubricant first time around and replacement if it continues........Mine has gone on both front doors.....couldnt live with the noise on top of ****** tinnitus!
Best of luck:cool:
