coil springs ml320 how to replace
2SSB
MANCHESTER
ml 320 1999
any body have an exploded view or pictue on how to replace rear coil springs have a rough idea but just wondering if anyone knows of any hidden little secrets
ta rick
Tight job, but not hard, n/s harder than the o/s one!
It is here
If you would like the info on how to remove please ask
kebo57
Lanc's
ml270
It is here
Hi Malc I would like the info if your sending it out mine as done 213K so its not going to be long before I'm changing them
Thanks Kevin
Thanks Kevin
I will print off and do that Kevin
I need a Email address Kevin
ta rick
I have Emailed you the fitting instructions
ta rick
Sending it out now :D:D
Make sure the bottom joint goes into the wishbone straight, other wise your spend a while with a file!
Sorry to be a pain but could one of you please forward the instructions to me as well. Thanks in advance Dave.
I have sent it Dave :D:D
Uncle Benz
West Sussex
Mainly Mercedes
I recommend replacing the pair in one go. I replaced just the offside (as per customer instruction) on one the other day, and it felt slightly strange in the corners afterwards - not particularly unnerving, but the feel was not the same on right handers as the left handers.
Delom
rye
99 ml320 lpg
ml rear coil spring removal
It is here
if possible please could you send me some instructions on how to remove n/s rear coil springs. thanks very much
