hope you can point me in the right direction.
It is an 1998 petrol with 1,4 litr engine.
Battery has enough power, all lights come on , but it doesn't fire up.
RAC man sprayed starter aid into the airfilter outlet, - started ok.
Also once it has warmed up , appears to start ok again as long as engine is warm.
so probably some sensor. But there are quite a few. And the location?
For example:
On http://www.aclassinfo.co.uk/mypage.1.htm under bulletpoint37, it lists all sensors. But my mechanic couldn't find the location of air duct temperatur sensor. Wasn't where it was meant to be
Could be the water temperatur sensor? But where is that located?
Someone suggested the OVP relay.
Apparently the symptoms are similar to those of a faulty crankshaft sensor. Should I have that replaced?
Scratching my head ,
Thanks for any suggestion
Claudius
For example:
Claudius
